It is currently Sat Aug 09, 2025 12:30 am
 Post subject: X brace 99deg angle.
PostPosted: Mon Oct 23, 2017 7:26 pm
So one thing I struggle with is getting the x brace angle exact.
I end up with way too much slip in the joint MOST OF THE TIME, and end up cutting new x braces until I get it right.
How do you guys get that angle just right and tight? Mitre box?
Jig of some sort? Or are you just a LOT better at it than I am haha
Thanks for any advise
B
 Post subject: Re: X brace 99deg angle.
PostPosted: Mon Oct 23, 2017 7:48 pm
B
40$ dado set on the tablesaw, a block for each model to set the angle of the mitre gauge, a stick with lump on the end to keep them aligned if you need to cut slightly deeper...ImageImage
I bet if you put 'stick with lump' in the OLF search box you'd probably find a thread I put up a long time ago about it...
These users thanked the author meddlingfool for the post (total 2): SnowManSnow (Tue Oct 24, 2017 6:30 am) • Pmaj7 (Mon Oct 23, 2017 9:36 pm)
PostPosted: Mon Oct 23, 2017 8:36 pm
First name: Danny
Last Name: Vincent
I just lay the braces out on the poster board brace layouts I have for all models. Mark, cut undersize and finish with a file. I then glue the x together on the marked poster board in the go bar deck. Don't forget the plastic wrap!
PostPosted: Mon Oct 23, 2017 10:00 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Similar to Danny, I position the braces on the plan for the guitar, mark the cuts, cut slightly under size with a pull saw, and in my case make any final adjustments with a chisel.
PostPosted: Mon Oct 23, 2017 10:51 pm
Lance posted a tutorial a decade ago, and it's the method I use to this day. Lay out your angle with a protractor, then use a straight piece of lumber as a fence. I use a 1/4" wide X, so I use a 1/4" downcut bit in my router. Route the slot using your "fence" as a guide. If you have a router table, use the miter jig for an easier cut. Look up Lance's tutorial for pics. It will be clearer.
I use another method to cut my lattice joints. I have a block cut at the appropriate angle that I use as a guide. I use one of Stew-Mac's nut seating files to file the slot, using the guide to keep my slot at the correct angle and square. It's quick, and the location of those slots needs to be incredibly precise or the braces that make the lattice won't fit together.
These users thanked the author James Orr for the post: Jonny (Thu Oct 26, 2017 1:29 pm)
PostPosted: Mon Oct 23, 2017 11:35 pm
I too used the Lance method for a batch, then was planning to move to the dado because it seems more straight forward. Great idea with the blocks Med! Now James has mentioned the Rtable miter, That sound even better yet. Hmm....
PostPosted: Tue Oct 24, 2017 2:08 am
http://www.luthiersforum.com/forum/view ... mp#p595810
PostPosted: Tue Oct 24, 2017 2:14 am
A bit of an expanded version, except now I use the dado blade.
Interestingly enough, since I got my Laguna SUV, I use it for pretty much all my straight cuts. The tablesaw now permanently holds the dado blades, which is also the correct cut for truss rod slots.
So all I need to do now is adjust the height when switching between cutting an x lap or cutting the t rod slot...
PostPosted: Tue Oct 24, 2017 7:29 am
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
Zip/Postal Code: 30501
I use a quarter inch bit with a guide bushing with this jig. The braces are clamped underneath with sacrificial strips by the bolts.
Good judgement comes from experience. Experience comes from poor judgement.
PostPosted: Tue Oct 24, 2017 10:08 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
That's basically what I do too but I uses a protractor gauge to lay out the line.
I can have the whole thing fitted in less time than I can set up a router or table saw. If I were doing several at once, that would be a different story.
Bryan Bear PMoMC
PostPosted: Tue Oct 24, 2017 11:24 am
I use a router jig with an appropriate bit. One trick is to thickness the brace just a little thick before routing. Say .030 for a .025 cut. Then sand the sides of the braces with a flat hard block until you get a squeek fit. Would work for a table saw cut as well and for getting a tight fit for back braces in the center strip slots.
PostPosted: Tue Oct 24, 2017 3:43 pm
I'm just a one at a time guy, so it's pencil lines on a bench hook type thing-a-me-jig for the angles, and an fine Exacto pull saw to the half way through line marked with a Veritas wheel gauge. Cut a bit shy, if anything, on the width and finesse with file.
Chisel out the waste in a nut and saddle vice.
PostPosted: Tue Oct 24, 2017 4:24 pm
Where's the Big Red Check commodium?
Didn't even use a Veritas. Just marked each side and freelanced it, filed it to fit...
Chiseled out in a vise set close to depth.
Users browsing this forum: Bing [Bot] and 43 guests
